I finally got round to working on my AU-D11 II (having redone the AU-D9 to use while the D11 II was on the bench). As a starting point I reviewed all of the threads that I could find on AK dealing with the D11 II, as a result of which one of the decisions made was to upgrade the whole amplifier to metal film resistors, as per LWBs posts in the DIY forum.
Reviewing the threads also brought up a number of issues, some of which I already knew about, and I decided to address these points and try out some solutions in going through the amplifier. These include the infamous 'Hot-Ground' offset drift, the use of constant current diodes or zeners on the driver boards, and the fact that some of the boards, especially the drivers, have piggy-back components strapped across others from the factory.
First off here are some of the dismantling pictures. In general the condition was not too bad, with really only the Power Supply board suffering from the glue problem. The amplifier is a European spec machine, and was working well without faults before I started, so no trouble-shooting required.
