Rega arm on Linn Basik plinth
losthorizon
Well-Known Member
I have a very good quality Linn Basik turntable that I purchased some time ago without an arm, and I have an RB300 Rega arm that I would like to attach to the Linn plinth, I know this is not straightforward as the Rega arm is longer and so its position on the plinth will need to be moved, I have measured from the centre of the bearing to the 222mm that the new hole would need to be drilled at and it all seems to fit, Has anyone successfully done this and have they come across any problems?
