I have a Kenwood KD-500 deck, on which I'm planning to install a Rega RB-202.
This used table came only with an SME armboard, onto which I mounted a Rega RB-250, using an armboard converter purchased from an English purveyor of custom tonearm parts.
Unfortunately, the RB-250 turned out to be defective.
Now I'm looking at the Rega RB-202, a newer model based on the RB250 that has the newer three-point mounting system, which involves three screw holes surrounding the larger center hole that the arm column descends into.
My questions are this:
1) Is the new Rega column the same diameter as the old one?
2) Is it possible to refit (by drilling three holes) an older Rega armboard to accommodate a newer Rega tonearm? Has anyone successfully done this?
Thanks in advance.
Thanks in advance.
