sumocomputer
I have a Rega P1 turntable, which I have had for about 1 year, running it with the supplied Ortofon OMB5e cartridge and the stock RB100 arm. I have been happy with the turntable, but started getting some better vinyl, so I decided to upgrade to an Ortofon Super OM cartridge, and 20 Stylus (OM20 when combined).
In any case, I ran into a few issues when trying do the proper "Advanced Setup" from http://www.audiophilia.com/features/cartridge_setup.htm, and hoped someone might be able to point me in the right direction, or just confirm my assumptions. Even though I am having issues, I will say the sound is pretty good, but of course want to make sure I am getting the most out of the unit. I found tons of info on all the setup instructions and what to listen for, but not on some visual sanity checks to do after your setup is done.
1. Using a Shure SFG-2 on a level turntable and anti-skate to 0, I set the tracking weight to 1.5 grams. But when playing records, it seems like the cantilever is almost bottoming out, at least compared to the OMB5e. It seems that with a little record warp, I should see the cantilever should move a bit, but it does not, though the arm does very nicely. The cartridge bottom has some clearance, so it never hits the vinyl. I have photo at the link below, as this is my biggest concern:
http://www.flickr.com/photos/coffeeguy/2758213196/
2. It seems like getting the right alignment using all the common protractors out there might not be possible with this arm. The biggest problem I ran into was that I simply could not get the stylus far enough forward for the inner alignment point on most protractors. I found a Stereophile article somewhere that confirms it is the headshell slots that are to blame. So I ignored this part, and followed Rega's instructions of lining up the tip of the stylus with a special hole in the headshell. Hopefully this is OK.
3. There really isn't any Azimuth adjustment, so I just ignored this part. It seems very close to parallel to the record. Hopefully this is OK.
4. There isn't really an Arm Height adjustment without shims, so I just ignored this part. It seems very close to parallel to the record. Hopefully this is OK.
I have a Hi-Fi News test record on the way, I was planning on using that to further fine-tune the anti-skate and possibly the tracking weight.
Thanks for any other help or pointers.
Chris
Chris
