troika
My vintage mid-fi system had become unreliable, so I've been replacing components. The relevant bits are a Creek Audio A50iR integrated amp that I picked up used without it's internal phono stage. When I bought it I picked up the cheapest Pro-Ject MM box (~$80) and used it with my vintage Philips 212 turntable. Before I parted with the outgoing receiver I tested the Pro-Ject stage against it's internal stage and was shocked at how much better the Pro-Ject stage sounded.
But, my vintage turntable became virtually impossible to set up and I brought home a used Rega P3 with a new, old stock Bias2 cartridge in it (on trial). I was absolutely blown away by the sound, specifically the doublebass, I am a jazz bassist and most of my LPs are 50s-60s hard bop and I just couldn't believe that it was possible to hear that sound coming off of records and into my room.
...so I convinced myself that the way was forward and instead of buying it, I bought a new P3 with a new Exact cart. Rega evidently has a supply chain problem so they are temporarily shipping P3s with the Exact vs the Elys cart and I decided that at this point it was worth the few hundred extra to get the best Rega cart. The shop also had a used Rega Fono MM MK3 and I just went for it on the belief that some of the goodness of the better cart might be lost on the entry level phono stage.
So, had I gone from Philips directly to here, maybe it would have had the same effect, but honestly, I'm not sure it sounds as good (as the used P3/Bias2). Specifically the bass is less tight and distinct. I know that Rega carts are not universally loved, but I can't find any indication that the Exact shouldn't be kicking the crap out of the Bias2, which I really couldn't read anything good about. So, I wonder if the difference is the phono stage. In fairness, the system as a whole sounds good, very good in fact, but I am missing that tight, nuanced bass.
I also can't find any review that suggests there is a better MM stage for a high end Rega cart and tone arm than the Rega, but I wonder if anyone has any thoughts about what might be going on.
I believe that both the Project stage and Bias cart had effectively zero hours on them. The Exact cart and new P3 definitely do, they were sealed in the box and set up by the shop. I did check alignment and tracking force and both seemed to be within about 1% of perfect. I plan to check them again when I felt like I had burned everything in. So far, I have played 29 LPs through this system. The Rega fono MM was used, so presumably it was broken in to begin with.
I don't want to start chasing nirvana, this system sounds very good and the one it replaced was unreliable. I wonder if sourcing a Creek stage would tighten the bass back up, if someone here thinks that will happen naturally at about the 50 hour mark, or if perhaps I should tweak the turntable setup a little bit.
Thanks in advance.
Thanks in advance.
