panjin79
Hello! Looking for a little advice. Currently running an Exact 2 on my P6 through a Schiit Mani. The Exact is almost ready for replacement, and I figured I'll improve on the Mani at the same time. I like the Exact, but I feel like I can do better. I listen to a lot of jazz, post-punk, rock, and extreme metal. I generally go for a neutral tone through loudspeakers and use a tube amp with headphones if I want to warm things up.
My budget is about $1,000 +/- $500 or so. For the cart, I've been thinking about either going with an Ortofon Bronze (more money for the phono stage) or upgrading to a Rega Ania. For the pre, current options I've come up with are:
1. The Puffin. I'm fine that it's a DSP box, not an analog purist.
2. Rega Fono MC with the Ania.
3. Used Graham Slee Reflex
I'm not concerned about matching to my amp, which is an early 00s Harman Kardon AV Amp into a HK power amp feeding Maggie 1.6s. The HKs will be the next to go. Right now, I think the biggest bang I'll get is the new phono stage.
Curious to get some opinions and suggestions...
