Hi I am new to AK and would like to thank you in advance for any help you can give me!
As a teenager I loved my hifi but after I got married and space was limited it got put in a box in the loft...where it has stayed for the last 30 years... until last weekend when I connected my TT (Rega Planar 2) to my amp (NAD 3020A) and speakers( AR 18LS) to see what it would do . I was amazed to see that it seemed absolutely fine, but on close examination I can see that the output on one channel of the amp is quiet - but it seems to work OK if I press MONO.
I swapped speakers and cables around which made no difference - it was always the same channel which was quiet. So it looked to me like the problem was in the output from the amp. But I then plugged my iphone into the AUX input using a 3.5mm jack with 2 RCAs ...and both speakers worked fine!
So that got me thinking that the outputs are fine and maybe the problem is either with the TT or with the PHONO input itself...and I am a bit stuck as to what to do next.
I was thinking of plugging the TT into the AUX input to see if it could be heard in both speakers that way (my iphone test confirmed that this one worked fine) and if so then I will know that the TT is not faulty..., but I wasn't sure if this might damage something and so I thought that I would ask an expert for advice before I did anything stupid.
.I also thought about giving it a good clean and so I have a can of Servisol Super 10 at the ready - but tbh I'm not sure how to use it and I dont want to damaging the circuits by being clumsy.
If anyone can help me isolate the fault and give me some idea on how to fix it I would be eternally grateful as it is driving me insane !
Many thanks
John
Many thanks
John
