I purchased the beautiful wood plinth rega planar 2 knowing about the issue the r200 arm possesses. I have gotten in too deep now… The anti skate mechanism fails due to the manufacturer of the arm using a belt (that turned to dust over 40 years). This can be solved but the process is known to be very challenging. Upon taking apart the arm I found the cuing lever to be leaking quite a bit, the wiring previously touched and now should be redone, and obviously there is still the anti skate issue. I have stopped on my mission to fix the belt as I believe this arm is a lost cause with all these issues. I have decided to forgo the operation. This turntable is in cosmetically perfect condition. It looks brand new. It’s shocking how good it looks. So I don’t really want to give this table up for someone else to have. Since the arm has failed due to its very old age I thought it would be nice to completely add on a new rega arm. However, I was unaware that every rega arm is very expensive. I could almost buy a current day rega planar 1 or 2 at some of these prices. If I go the replacement route, I’d like to keep a rega arm on the rega table (previous original arm was not rega). I’d like to only spend about 200 dollars maximum on it. Does anyone have a model off the top of their head that fits my situation? I also wanted some opinions on people modding differently than the original. Is this frowned upon? I am in college and have gotten into buying and fixing, I’m not huge on cash and I don’t know nearly as much as you all. I could use some general guidance and recommendations here. Thanks!
