Cabdiver
Member
The Rega Planet that I bought a couple of years back worked fine until one day it wouldn't turn on - no lights, nothing. I plugged another CDP into the same outlet and set-up and it worked fine. I took the Rega down to my work bench, plugged it in and it worked perfectly, played a CD w/o problem. So, back upstairs, plugged it in and again nothing. Back downstairs, the lights came on, but then faded to black after a few seconds.
I did some reading and learned that the 1N 4403 diodes are often a problem with this player, so I bought some 1N4004 diodes (which I've read are a suitable replacement for the 1N4003s) and replaced the old ones. Plugged it in and - tadaa - the lights came on. Only now it won't read a CD. A new problem. Not much for believing in coincidence, I figure I screwed something up, especially since I discovered the odd three-wire, tucked through the little plastic thingy on the loading mechanism. I have no idea where this thing goes, and no idea if it has anything to do with the disc-reading problem.
As an under-educated hobbyist, I've cleaned the lens, remelted a few suspect solder joints and re-lubed the laser mechanism rail, none of which helped. I'd appreciate any suggestions or help with this. Thank you all, as always!
