SaSi
Seriously Illogical
Some time ago I wrote about my Revox PR99 and how it showed very good frequency response but instability in reproduce level.
In other words, while playback of 1kHz tone was constant at 0dB, 1 16kHz tone would fluctuate during playback by at least 1-2dB. At even higher frequencies, there was a drop in response and an increase in fluctuation.
I was told this is a result of worn out heads and a mirror formed.
Last night I took the heads off, took pictures of them and relapped them. They did have a rather large mirror, about 5mm for the playback head and ~4mm for the rec head.
The relapping process isn't yet finished (the final polish hasn't been done yet), but I put the heads back and alligned them to check how they do.
Well, the fluctuation has gone by a large factor. There still is some, but with a quick check using the deck's VU Meters, it is in the range of 0.1 ~ 0.3dB - as far as my eyes can see in the VU meters. I will recheck with the oscilloscope for precice measurements, and continue the polish process, posting pictures of that in the DIY forum.
What I would like to share here now is that the process is far simpler than it sounds and I would never consider sending the heads for pro relapping unless I was actually using the deck for commercial purposes. Having a set of extra heads to try really did help giving me the opportunity to try without destroying.
Also, the metal is pretty soft. I cannot remember sanding anything softer than that permaloy metal other than tin. Actually, permalloy is 20% iron and 80% nickel, so that explains it.
