mandoblast
A bit of searching didn't turn anything up, so I thought I put this out there. Anybody tried this? Background: I'm finally getting around to wrapping up rehab/updating of a Grommes receiver model C502 (not real common, I guess).
Unit was in good original condition. Replaced coupling caps and electrolytics under the deck. Big cans are alright. Changed to individual fixed bias. 330v on the EL84 plates, 300 on screens.
I was pretty happy with the sound, except for the slightly flabby bass. I tried some wild output-cathode feed-back schemes and did get tighter bass out of them, but wasn't really happy. I was kind of just goofing around with it, so I'm not sure I ever did it the 'best' way. But I was also aware of how this would increase the drive requirement to the tubes, so whatever gains I made in tightening the output would be erased by distortion in the early stages as they tried to overcome the cathode feedback. Chasing a moving target... I think this is what I got.
Fast forward: With the output stage returned to optimal, I disconnected the feedback resistor from the 16ohm tap and ran a pair of wires straight from the backs of the speakers to the feedback cathode resistor, top and bottom. Well, through a 100k pot. Wow. Done. Sound is better with LESS feedback (dB's) than with the feedback coming from the transformer tap.
'Remote sense' is the term used in power supplies for a provision to bring a small wire back from the load to show the regulator the actual voltage across the load. Since the remote sense is high impedance/low current, it isn't affect by resistive losses over the run.
Roger
Oh. After all this, I guess I should do better than just sticking stripped wires into the backs of my speakers. Hmmm.
Roger
