RunOutGroove
Addicted Member
So I got one of these turntables, a couple of years ago... and it's really the best turtable that I've owned (out of admittedly only a few not very high end ones though). The Denon DL-110 cart that it came with sounds great and tracks well, but now I'm wondering if after a few years of use just how worn out it is (hopefully, it's got plenty of life on it as I'm not really looking for a reason to replace it). I have a little mini microscope gizmo (with a built in light) that I figure might be good enough to see wear on that thing, if there is wear, but in order to check that I'll need to take the headshell off and I can't figure out how to do that. On the tonearm, where it meets the headshell, there's a little screw with a knurled knob that would seem to be the thing that holds the headshell on, but when I loosen that thing, the headshell doesn't seem to be coming loose and of course I don't want to force it and risk breaking the delicate mechanism of this thing. Is there some kind of trick to getting that headshell off of the tonearm?
I realize that I could unhook the wires, and unscrew the cart from the headshell and then re-calibrate everything when I put everything back together, but I really don't want to do that. I think that before I do that, I would just bring the whole thing to the hi-fi store in my neighborhood for them to deal with, but I'd really like to avoid that hassle (and expense)...
