markdi
Natural born thread killer
ok
I got a pair of klipsch kg 5.2 speakers a while ago.
one of them every so often would make some sort of rattling sound from the 10 inch driver.
I took a look at the driver and found a small hole/tear in the rubber surround.
about 4mm by 3mm or so.
Nearest the outside edge next to the frame of the driver.
I bet I was hearing air leaking out the hole.
what should Use to patch the hole ?
will the acid in silocone or other glues damage the rubber ?
how should i apply it so that the repair is not visible ?
do i have to put a new surround on the driver ?
