Love my old AX but the left channel sounds slightly "dull" compared to right channel. At first I thought it was just a volume difference, but it also lacks some brilliance compared to the other channel. Sitting at ideal listening position, the right channel sounds brighter and louder.
I have switched speakers and cables to eliminate external sources. The fault is present on all inputs and both A and B speaker channels. Bypassing the EQ does not help.
I recently cleaned and re-lubed all switches and pots and they work fine. I also calibrated the idle voltage according to the service manual. The left channel had notably lower idle voltage, so for a moment I thought I had found the problem, but calibrating the voltage did not help. I don't have much experience with fixing amplifiers so would like some advice to what my next step should be.
Manual link:
Yamaha AX-540 Service Manual
Any help much appreciated!
Manual link:
