Tibidabo
Hello all vintage HiFi adepts, I have a question regarding the repair of a set of Iconn connectors.
Just recently I laid my hands upon a set of MIT Terminator 4 Enhanced Image EEAR 7.9 cables.
It turned out one of the cables didn't work due to a small cable break in one of the connectors at the connection side of the amplifier.
I opened up the broken cable end and to my surprise the wire is connected to the Iconn connector with a small copper clamp. It's not soldered. By removing the clamp it unfortunately broke.
Question is should I use a new small copper clamp to fix the connexion again to the Iconn connector or is it better to solder it on the connector (if possible).
Thanks for your advice.
