Most SA-9100 schematics (all that I could find, anyway) show the AWM-025A board, mine has an AMW-025C with a resistor (R29) that doesn't appear on the AWM-025A board.The person who worked on this before me replaced R29, a 47k resistor per the AMW-062 schematic, with a 2.2k resistor. The result was -10v on the base of Q6, which caused the unit to make a popping sound when powered off.
The AWM-062 board layout does appear to be the same as the AWM-025C as far as I can tell... see the thread below:
https://audiokarma.org/forums/index.php?threads/sa-9100-protection-light-on-and-off.793948/
I realize this error was unlikely and specific to the unit I repaired, but hopefully the info will help someone. The only reason I can think that someone would have done what they did was that the A board schematic shows a 22 ohm resistor in a place where someone might be confused if they didn't realize they were looking at the foil side, but I have no idea. I am not a tech, by the way, I am a hobbyist, please correct/advise/add info if needed. If someone could link to the proper AWM-025C schematic that would be great.
