I just purchased a pair of small MCS model #683-8229 speakers from the local Goodwill for $6.99 / set.
The Woofers will need new foam surrounds
Each of the two cases had been dropped on their rear corners and the seam had split at point of impact
( roughly 1/6 to 1/8 inch openings) .
The woodgrain finish along the damaged seams has also separated from the wood, necessitating recovering.
Oh, yes. These are the best condition speakers I have seen in thrift stores for many months.
Bough 'em mostly because I have some MCS gear already but no MCS speakers.
While I would prefer to disassemble each particle board case into it's separate components for refurbishment and reassembly, I do not believe the glue bonds will permit assembly without irreparable damage to the particle board.
Next option would be removing the speakers , +/- 20? dB three way switch and interior padding before using a saw blade to clean out the split seam and attempt to add glue and re-clamp.
Final option is make new particle board enclosures and transfer internal components.
Anyone have experience dealing with split seams on particle board speakers?
