Repair tech in the SF/Bay Area?
Salad
I'm sorry if this is the wrong place to do this but I'm in need of a Marantz repair tech in the San Francisco area. Does any know anyone they can recommend?
2285b
Makes a "thunk" sound when unit is turned on.
Need to be relamped.
Thanks for any advice.
2285b
Salad,
Try doing an AK search. This was covered in the past. There are a couple in SF and Berkeley but I don't remember the names. I've used Sertech down in SJ with great results.
Replacing the lamps is pretty easy and you might consider doing it yourself. Again do a search on the topic for some detailed "how tos". You can get the lamps from AKer dgwojo or a number other of places.
So where is this "thunk" sound coming from? Try listing the symptoms. I'm sure the guys here will be able to help you out.
Good luck.
