Zeb, Are you offering to fix my heatsink?I'll fix it for the member
I've had good luck with this stuff on metal parts but haven't tried it on heat sink fins.
https://www.amazon.com/J-B-Weld-826...keywords=Metal+Adhesive&qid=1606419239&sr=8-4
Probably JB Weld...How ya going to fuse that piece to the fin? Just curious. ..
And a coat of paint. That is what I would do.That's good shiite, just mixed up a dab 2 days ago to cover a coolant tank crack in my beater money-pit volvo wagon.Probably JB Weld...And a coat of paint. That is what I would do.
Nice work @zebulon1 .....I have worked with all kinds of metals for most of my life....would have been the way I would have picked to fix it!You really need a donor heatsink to repair severe damage.
You can't weld the pieces back together. I had a pro at the Trane (Lacrosse, WI) HVAC company's maintenance welding department give it a shot. If Brian can't weld it, no one can.
JB Weld is the best route, plus a regular guy can sort it out using a Dremel, EZ406-02 metal cutting kit. DigiKey has them.
There are also many brands of low temp brazing rods for use on aluminum that you can use with a propane torch.
I'm thinking that some heat at that corner to anneal the aluminum, bend it straight, then sand and fill over teh crack with epoxy. Re-sand and refinish. Of course. it will have to come apart for that.
