Thanks Biggles, I'm about to fix some corners of a pair of Klipsch La Scalas. I'm doing a bit of research. Ended up here this evening. I will be fixing corners and veneering the monsters.
thank you! good info!!!!Repair the Monitor 10...
Building up the damaged edges is actually the easy part. That's some plastic wood filler, layer of in and with a few application fill in the ding. Keep saying any protrusion until you have a nice smooth square edge.
You can't fix the vinyl. Some people use replacement vinyl. I never have. If you are able to buy a dark colored wood filler then that might kinda blend it. Last option is to veneer. Fair amount of time and effort plus the cost so you would want to evaluate that.
I would probably go with the dark wood filler and hope for the best. If the filler color is not close enough you could try staining the filled bit. The filler will grab the stain and you would just wipe the excess off the vinyl as obviously the stain won't penetrate the vinyl.
good point, thank you, Im a novice so not sure if im going to veneer... think for this weekend will audition the Polks in my audio room (400 sq ft) get a feel see how they sounds and if keepers....If you are going to re-veneer - don't even bother with stabilizing and wood filler - just lop off the affected corners and replace with real wood, cut off at 45 degree angle and then cut a corresponding piece off a board and glue in place - sand flush to the sides of the cabinet - done
Hi everyone! This is John hailing from Paris! Nice thread!! So I was given a pair of Allison LC120’s that I want to try and get working again. I’m going to reform the blown out speakers but I’d like to fix the bottom right corner on of them. The particle board has some damage due to water. Any tips on how I should proceed would be helpful. I’m pretty handy but have never worked with speaker cabinets before. Thanks!!Thanks for the reply. I was thinking if there was a way to carefully peel back the veneer or cut it and separate it from the board I could rebuild the board then reuse the veneer. Is that possible?You are into a major repair. Various methods but there is no satisfactory way to recompress the particle board.
I might try cutting/hacking all the swollen loose stuff out and rebuilding the corner with filler. Then fresh veneer.
Of course that also means both speakers plus stain and clear coating so a fair sized job when all done.
