I am restoring a buddy’s Hartman Kardon 730 twin series receiver today and I’ve found why none of the external inputs work: the rear panel RCA jack input board is physical cracked or broken and that has broken traces and interrupted the circuit path.
I’m thinking I can clean the two mating surfaces with some IPA, blow it out, bend the two pieces mostly back together, dropper some super glue in the crack, close the two faces together, then hold the broken board faces together for an hour with hemostats clamping across the two sides of the board.
Then carefully make solder bridges across all the broken traces. For any wide gaps I’ll cut 2mm long station wire pieces and solder one across the two sides of each broken traces.
Is there a better, smarter way, AK? Help me help a fellow AK’er with some sage advice, please.
