Anonky
Kenwood KR-9600 / Pioneer SX-950 / Sony STR-GX10ES
Optimus 4s have a woofer two identical tweeters, each of the tweeters are 16 ohm. None of the tweets were working so I disconnected the tweets from crossover and none had continuity. Didn't appear to be a simple fix on any of them (broke tinsel lead, etc), so I've ordered replacement 8ohm 2 in paper cone tweeters as a drop in replacement but now that I'm thinking about it more, will the difference impedance of these tweeters (original 16ohm vs 8 ohm replacements) cause an issue? I'm relatively new at this and have not tackled modifying a crossover so hopefully I haven't accidentally signed myself up for that. Depending on what all I would need to modify, I think it's within my capability.
I'm also reading in other threads that if I only used one 8 ohm tweeter in each cabinet instead of two in each cabinet that might work. I'm not totally opposed to this idea if that is my only option without modifying the crossover. I like these speakers mostly for the novelty of them being able to double as stools in a sun room anyways, but I would like to preserve their "omnidirectional" aspect if possible. Any advice is appreciated.
