The schematic I have shows the cathode of that zener should be +14.0 vdc and yours measures 14.6 vdc. I would try replacing it with a 14.0 v zener if you have some to select from. Leaky old electrolytic caps and dying transistors are also suspects.
Ah. My assumption was that 14.6vdc was within 5% tolerance and therefore was acceptable. In your opinion do you think it's worth replacing the zener with something with a 2% tolerance like this? https://www.mouser.com/ProductDetail/Nexperia/NZX14B133?qs=sGAEpiMZZMtQ8nqTKtFS/ISyHb0gtGyWq8NiIgMhDkA=
My long term plan was to do some recapping anyway so I'll probably do that sooner rather than later with some of the adjacent caps. Thanks for the advice and thanks also for the transistor replacement suggestions. Do you think that's more likely to be causing the offset than leaky caps?
(My OCD is showing).If you have some cheap speakers you could try running it the way it is, if the bias is adjustable. Since the offset is not adjustable the manufacturer was not all that worried about it, and a few hundred millivolts is not a dangerous amount of offset. Some say that much affects the sound quality. Some of us perfectionists will spend way more time trying to get it perfect than it is worth. YMMV
400mV offset, to me , is a problem to be solved. Not OK . Up to 100mV, I'd try the amp anyway, but not with 400mV...
The 2SA798 always go bad, so that would be the 1st thing to do, to replace with 2 KSA992. If you buy them from Mouser, they come in a cardboard strip, so they are from the same batch and closely matched, you don't need too many to get a matched pair.
If you have 400mV right at the transistors bases, try to see where is that voltage coming from. It could be even a leaky capacitor letting DC pass from a previous stage. Try to disconnect or remove the coupling capacitor coming from the preamp section. (C601 C602)
Exactly what I meant. Now that it is "functional" its time to get it fixed correctly. There was no point in trying to just correct the offset if it had a bigger problemThe bias is adjustable since this is rcs16's design that includes the variable resistors at R7. I have some cheap-ish speakers and it doesn't sound half bad even with the bias. I'll probably end up messing with it to get it under 50mv.![]()
Joe,I recently acquired a Sherwood AD-2210CP.... found this thread searching for DC offset and STK modules.
Work I've done:
-performed a e-cap replacement
-swapped out 2SA798 with KSA992 pairs, thermally connected
Overall this amplifier sounds nice.
This unit uses STK1030 modules. So far the best the DC offset measure is 44mV / 34mV for the left / right channels.
I was wondering if zener replacements might be warranted or if I'm just splitting hairs to get the DC offset lower.
- WZ197 rated 20V measures 21V
- WZ150 rated 15V measures 15.9V
- WZ240 rated 24V measures 23.5V
All are within the +/- 5% spec
I probably should leave well enough alone.... but any thoughts may be good.
Thx,
Joe
Joe,
I don't see a problem with your voltages, dc offset less than ±50mVdc is fine.
Since this thread is about a different unit you will probably get a better response if you start your own thread and continue from there.
And welcome to AK!
