Decibel_116
AK Subscriber
Does anyone have any recommendations for replacing a Dynaudio D28AF tweeter? The tweeters in my Thiel CS3.5 speakers have developed some distortion. I am not sure if the voice coil is blown, needs the ferrofluid replaced, or if the dimples in the dome are causing this distortion. A Google search doesn't turn up much in the way of replacements for these drivers. I am attempting to locate a reasonably-priced replacement with comparable performance. So far, the searches have come up with a pair of Morel "acoustically matched" drivers, model number ET-338. I found one review for these which was positive, but these are quite expensive for replacement parts ($360/pair). The Dynaudio D28AF came as factory-installed equipment on several "high-end" speakers from Thiel and others. I do have a set of Thiel CS2 that uses the same tweeter. I will most likely pull those and put them in the CS3.5 speakers to keep them original. I will need something comparable to replace the ones I remove from the CS2 set.
Any advice and/or suggestions will be appreciated.
Cheers,
David
Cheers,
David
