Rey1
Hi everyone,
I just became the owner of a Sansui 210 receiver. Everything works except the dial lamps and signal meter lamp. Checking this out furthur I found that both fuses for the dial lamps were blown. They require 6.3 volt, 250 mill amp fuses. I can only find 6.0 volt and 8.0 volt fuses on the web. Which would be the best fit? Also, should I expect the blowout to reoccur when I replace the fuses?
Any suggestions will be appreciated. This is my first sansui and it sounds great
