Replacement motor for Dual 1219
Mikael Webb
Hi.
The motor in my Dual 1219 has broken down and my tech guy says it has to be replaced. I stumbled across this motor on ebay but would like to be certain that it will fit before I commit. I've read that 1019 and 1219 have different motors and this one supposedly works for both, which is a bit confusing. Any help is greatly appreciated.
What makes your tech guy say that? The only thing that makes a motor like that bad would be physical damage or open windings. Did he test for continuity?
Oh, now you´re asking questions I can't answer ;). The guy runs a small repair shop and I don't think he has any special knowledge of turntables. There is another guy a couple of hours drive from where I live who specializes in Duals. The problem is that his shop is only open during office hours, when I work. The turntable was working up until a couple of weeks ago when the motor started to make a noise. I tried to service the motor by following the service guide for amateurs available online. I must have done something wrong as the motor was dead when I put it back together...
Contact Bill Neumann at Fix My Dual. He has the largest parts inventory for Dual turntables in the US.Nice gentleman to deal with and superb customer service.
Besides reassembling the 2 halves crooked so the armature binds (easily checked to a certain degree by spinning the shaft by hand), doesnt seem so much could go south on the motor service.
What I could see being more likely is getting confused with which wire goes where inside the black box
Maybe I did reassemble the two halves crookedly.. Would that explain the motor not starting? I did give it a whack to align the bearings and I'm pretty sure it's wired correctly. Thank you for all your input!
