Replacement oscilloscope Knobs?
After playing with this for several days, it turns out the knobs can be made to work if a small piece of clear tape is stuck to the control shafts to increase their thickness. I cut the tape so it's the same length as the splines, but it only wraps around about one-third of the shaft. This gives the knobs a good grip, and there's no problem using them for the pull-push functions. Hopefully this will be a good long-term solution. :)
Once on a old scope used a rubber grommet that fit to work a situation like yours. Never did replace the broken knob. Should of saved the other knobs when it finally went south.
Alas did not.
