Replacement Power Switch?
sejose
Hello
My 1979 Sanyo amp has a power switch which I would like to replace. It is an Alps, with this printed on the top:
TV-5
SDU3P 934
I can find Alps TV-5 switches, but not knowing exactly what the specs are of the the switch I have, I don't know with certainty what a suitable replacement would be. I emailed Alps, and although they replied quickly, this is their response to my query as to a suitable replacement switch:
'Scott, unfortunately we cannot identify by the part numbers given. It
appears to be something that Alps Japan supplies for a specific application
with the customer's requested part number. We cannot get any information
from the factory on it. I would suggest matching requirement to the closest
part on our website (alpsusa.com). Parts can be ordered from one of our
franchised distributors, Mouser, Bisco or Avnet. Please let me know if any
additional questions.'
So I am putting this out there to the community: How can I be sure I have a correct replacement switch? Pics are of the switch I removed from the Sanyo.
Thanks
Scott
Your best bet is to pull that one apart and see if you can make it work. Upon reassembly, use a new safety-cap to protect the switch contacts.
You may well be correct. From the schematic, looks as though it is a dual single pole switch?
S1-1 and S1-2 are the power switch
Thanks Glen
Scott
According to the schematic, it's a DPST switch. Just the rear section is used, the front section may as well not be there at all. Any Alps TV-5 switch that is DPST will work fine, just make sure you get one that bolts in the same way as yours.
I've replaced similar switches to yours often, as that is the same switch used in the NAD 3020. Once they start going bad, no amount of cleaning will help, because so much of the contacts will simply not be there anymore.
Well I got the switch taken apart, and have cleaned the carbon deposits from the contacts. Tonight I'll put it back together and see how it works. The switch on the front doesn't seem to do much that I can tell. Two legs solder to the pcb, and they just trace to each other, no where else. Doesn't make sense except to locate and position the switch perhaps.
If I buy another DPST switch the pushbutton may not reach the front panel.
Ruesselschorf thanks, I'll keep you in mind if need be.
Scott
Repairing (replacing) Sanyo power switches
I have "repaired" several of these switches with success, as there is no exact replacement that I could find that would fit in the PC board.(no surprise) You need to really love Your Sanyo to go this far, however. What I did, was bolt a heavy duty PC/AT pushbutton switch (DPDT) behind the original, spaced and clamped such that the plunger and throwbar from the original switch was still utilized, resulting in a stealth apperance and feel when complete. The front section of the original switch has the throwbar through it and it emerges out the rear of this section, which can be used to depress a carefully "ganged" replacement switch mounted right behind it. All of these units will eventually exhibit this problem if used regularly. I wired in the new switch and removed the leads from the old. It works great and appears untouched. In Sanyo receivers, the front section of the switch is used, to mute the speakers just an instant before the switch is turned off. In this case, if the front section is unused, You very well may be able to fit in one of those "Marantz" switches that have been mentioned.
The way this switch works internally is really funky, there are more parts than need to be inside a switch, it was really no wonder to me why they fail, once I observed several disintegrate before my eyes when I attempted to take them apart. The contact surface area seemed to be adequate, but perhaps the contact material was not very good, or the design just likes to arc, and wears very quickly.
The method I described I have used to fix four Sanyo plus series receivers, it works, it may not be the only solution, and it involves a bit of mechanical creativity and aptitude (Kludging), So I will be interested if some other method or replacement part will also work.
Scott
If I remember correctly, the tip of the switch to the mounting plate is pretty much standard on all the Alps TV-5 switches, at least within all those that have the same type of mounting. I know if you browse through the Mouser catalog online, you can see line drawings of all the available Alps switches, to find the one that has the correct mounting system. In other words, if you match up the mounting plate dimensions, and where the button lies within those measurements, any switch fitting that drawing will work (at least as far as mounting and the button being the correct length).
Alright, excellent advice Sanyofreak and BrassTeacher. Thanks!
Tonight I will reassemble my original switch and have a go. Even if it works, I may secure a replacement switch to have in case of failure of the original part.
And I do love my Sanyo by the way :music:
OK Thanks everybody for your helpful suggestions. I did remove and take apart the switch, cleaned it up and replaced it. All better for now. Still I have right channel distortion. I'm just going to replace the output MOSFETs and go from there. Before I do that though I'll test the transistors on the left channel pcbs as well.
Thanks again
Scott
Hi Everyone!
I found this post while trying to find a replacement power switch for a NAD3150 stereo amplifier that uses the same ALPS TV-5 SDU3P switch.
Upon reading this thread I had opened the switch and found terribly burnt contacts on the main power side. I carefully filed away the welding chars and swapped the spring contacts with the unused opposite side of the switch for good measure. I reassembled it and tested it and it worked like a charm using the beep tester! However, after I re-installed the switch, I found that SOMETIMES (like 1/10) this cleaned/filed/reassembled switch would just not work... or it would flicker the unit on and off...
Well, that's just no good to send back to a customer that had a power switch issue to begin with...
After much digging I found another post (either here or on another site, I don't recall) that indicated the C&K NE1839EE should fit if you can salvage the bracket from the alps switch.
https://www.mouser.ca/ProductDetail/611-NE1839EE
Not many left, but for all its worth to the community. the picture on the mouser site does not reflect the actual product. the real switch is almost a drop in for the alps switch and it has nice little loops on the top so you can mod it for the application.
Rather than drilling new holes in the PCB I went for a wire jumper to the top of the switch and putting the safety cap directly on the switch rather than back on the board.
I hot glued the switch for added durability and the NAD was rocking again! No switch issues and no pop!
Good Luck with your restorations everyone!
Hi
Hi Everyone!
Hi Everyone!
Hi Metal L in Ontario Canada
I have a Sanyo A35 integrated amp with the power switch issue
Will your Mouser switch work on this Sanyo amp
Can you PM me
Anthony in Montreal
Hi
Can you PM me
Anthony in Montreal
Hi Anthony,
Can you send a picture of the switch PCB in that unit please?
I cant tell from the service manual what the footprint is for the switch.
Functionally it looks like it could work, but i cant be sure unless I see what's going on inside.
Hi Metal L
sorry for not getting back to you....in a long time. I was away.
Yes I will get you a picture of switch PCB from my friend who is working on it
Will do it during the week
Thanks
Hi Metal L
Thanks
Looking forward to seeing it!
hopefully the switch will work for you. If possible, can you get your friend to take pics with caliper measurements of the pin spacing for verification? that would help to ensure the part will fit properly. I have found a decent stash of these (NOS) switches at a local electronics surplus store, so I grabbed a bunch for the inevitable future where we cannot find real "power" switches anymore.
I have started doing some workarounds for customers with hard to find switches. I have designed a drop in triac switch that can use most old "dead" switches on a different contact pair and works beautifully for us 120vac single phasers that I may put up for sale if the interest is there.
For a customer whose switch was totally non functional, I designed a PCB to hold a latching "keyboard" switch (TL2202 style) to trigger the triac board and it has held up phenomenally for over of regular usage.
