Replacement rubber feet for 2105?
Hannes123
Greetings!
I am on the look-out for replacement feet. The one´s of the MC2105 i am getting, are repros/ugly aftermarket feet. Also, i am looking for a new speaker-terminal strip.
https://tinyurl.com/mr2yekhd
Are these the right size?
Thank you!
The original feet were plastic, not rubber. Sometimes they are missing because they are removed to fit it in a wood case.
As far as the terminal strip, the spacing isn't listed in the ad so no way to tell. Also, the originals are slotted screws FWIW. Last I knew they were still available from Digikey and other electronic suppliers, or you might pay more but get what you want from antique electronic supply / tubesandmore.
ok. for the feets, i´ve found these - should be ok?
shorturl.at/NRT13
thanks hannes
That's a ridiculous price for plastic feet. And, be aware that the screws may not be correct. Some Mc units had machine threads and some didn't. And if the screw is too long it will make contact with a circuit board and bad things will happen.
Larry
