Lawrence-lp
I think I now know enough to ask a meaningful question.
I have a Shure M97xE cartridge on a mid-level Technics turntable. My 4-year old son "not-so-gently" dragged the tonearm across a record and damaged the needle housing, so I started looking for a replacement, and then considered upgrading. I found all the raves about the Jico N97xE SAS needle, but found another option and wanted some feedback.
In terms of the shape of the actual needle (correct me if I am mistaken), I understand that elliptical needles are good but do not read very deeply into the groove; diamond line-contact needles have a sharper point and thus read deeper in the groove; and SAS needles are sharp but also contoured to make even more contact with the deeper groove images than a diamond line-contact needle.
I really want the deep-groove contact not only to get the most sound, but also to get past the superficial scratches/pops/clicks on most LP records. (I've heard the difference, and it is amazing.) I like a warm, rich sound.
So here are the options I found:
One is just the original stock Shure N97xE replacement for about $45, which I think has an elliptical needle.
Another is an LP Gear N97xVL ViVid Line replacement for Shure N97xE stylus for about $80. It is a diamond line-contact needle (sharper tip). One reviewer claimed it worked better than the SAS, even though he blamed himself for the difference.
The final choice is the JICO N97xE SAS needle/stylus replacement, which has the highly-touted SAS needle. It apparently once sold for $180, but now sells for $290 from turntableneedles.com, apparently because SAS needle production is being suspended. One reviewer noted it was absolutely worth the $180 price, but now that it is $290, I'm not sure that analysis stands.
The questions is, with a mid-range Shure M97xE cartridge on a mid-range Technics turntable, does it make sense to spend almost $300 on an SAS needle, or should I just go for the $80 LP Gear line-contact needle and call it a day? I can afford the $300 SAS stylus, but I'd rather not waste $210 (or would prefer using it elsewhere), if you know what I mean. Would I be better off upgrading the whole cartridge to, say, a $210 Denon DL-1 MK cartridge with elliptical needle, or the Denon plus a similarly-priced $80-$90 line-contact needle? Or would the M97xE cartridge suddenly explode into the performance of a $600-$700 cartridge once the SAS needle is on it?
Thanks.
Thanks.
