Mat86
So I'm trying to restore a Pioneer RG-2 processor, despite being a novice, and picked up a broken unit. Fiddling around inside I found a power transistor to be rather loose, and applying pressure would bring the unit back to life.
The part is Q32 in the service manual, appears to be a Mitsubishi B682 (pictured in the attachment)
I assume this means replacing the transistor and not just soldering it in tighter, right?
How do I replace a part like this? I'm only familiar with caps right now...what's an equivalent to this part, do I get it on a place like Mouser/Digikey, and are there any other (non-electrolytic) parts (ie transistors) in here that I should be replacing while I've got it open?
edit: 2 posts after making this thread I've completely lost all power, not just power to 1 function (when I made this thread I still got the power LED on at all times)
