Replicating a Forte III cabinet
DLStryker
If I'm building a Forte III cabinet and I may very well not have the mid and tweeter in the cabinet. Do the mid and tweeter take up enough air space that I need to reduce cabinet size?
Also, I am using the external cabinet size from the Klipsch website to determine internal volume. My Chorus II's have s 3.5" riser. Is it the same on the Forte III? My Chorus II's also have the front baffle board set back into the cabinets 7/16". Is it the same on a Forte III?
If someone knew the internal dimension of a Forte III that would be even better?
You’ll want to maintain the internal cabinet volume for the woofer and passive on the back to perform comparatively. What’s nice is, if you don’t want the HF drivers to share that box, the shape then would not matter so much. So you could make this woofer enclosure shorter and more box-like, then you could do a single baffle or separate box for the tweeter and mid to sit on top.
