NickDeO
Hello again, AK!
A few months ago, I picked up a Harman Kardon HK 730 Twin Receiver for around $160. I forget if the issue was "no sound at all" or "no sound in one channel" (I misplaced my original repair notes... whoops), but I had hoped that a recap and some DeOxit would get everything working again.
While working on the main amp board, I decided to test the main output/driver transistors. A few of them failed the diode test, so I ended up replacing all of them with new matching pairs.
Upon testing the HK 730 following the cleaning/recapping/transistor replacement, I was still unable to get a sound out of the left channel.
Unfortunately, I had been pretty busy between school/work/life as well as fixing up a friend's receiver, that my Harman Kardon had been moved to the back burner for the past few months following the initial work mentioned.
Now that my own gear is finally at the top of the to-do list, I was able to look further into the dead left channel. When I was looking for the service manual online, I actually noticed an additional "service bulletin" released by Harman Kardon that was specifically concerned with the loss of one channel. Nice!
I'll attach the PDF of this bulletin, but the main idea here is that the feed thru plug in connections used in this family of receivers was prone to issues that would kill one of the channels. For such a highly-regarded amp, I was surprised to see these type of connections being used, although I'm sure the corporate bean counters at HK would have appreciated the lower production costs.
Anyway, I looked over all of these connections, making sure to disconnect them, clean with DeOxit, and replace correctly. I even went over all of the solder joints and resoldered each individual pin on the mentioned boards. Everything then received an ADDITIONAL dose of DeOxit, including the Tape Monitor buttons on the front panel that I assume could also be a potential culprit in this case.
After everything dried, I tested the FM channel using headphones. Still, nothing coming out of the left channel!
On pg. 5 of the service manual, Power Amp Idling Adjustment is mentioned, but I don't see anything about Bias or center voltage adjustments for this particular model. To carry out idling adjustment, I need two 8ohm 50W resistors, which I should have by Friday. Could this kill the entire channel?
In the meantime, I think I might try switching sides on the pre/main in/out jacks on the back of the receiver. I assume that if i can get the right channel preamp to come out of the left channel main amp output, I can narrow the issue in the left channel down to somewhere before the signal reaches the power amp (i.e. the selector knob, tape mon. button, or maybe a semiconductor or poor connection in the pre-amp section). I'll keep everyone posted!
With all of that said, does anyone have suggestions as to where to look next? Thanks in advance!
