Research Question about Tape Speed
porkyB
The Nixon Watergate tapes were recorded on SONY TC-800B at 15/16 ipm on 0,5 mil tape. His secretary played back the tapes on a Uher Universal 5000. Uher specc list speeds. 2.9 / 4.7 / 9.5 cm/s. Could the Uher 5000 playback the SONY recorded tapes? Thank you.
Hi PorkyB,
I think you are in error here!! 15/16 inches per minute would make a recording that would be so muffled due to lack of treble that they would be useless.
The standard speeds for tape recorders start at 15 IPS (30 IPS) and then get repeatedly divided by 2. Hence 15/2 - 7.5 IPS, 15/4 - 3 3/4 IPS, 15/8 - 1 7/8 IPS and 15/16 IPS. I think some Logging Machines go lower than this.
The speeds for a Uher would be 9.5 cm/s, 4.75 cm/s and 2.375 cm/s. 15/16 IPS *2.54 cm gives 2.38 cm/s.
So the Uher would do the job.
Some of the recordings from Watergate were reputedly done with a Nagra SN (Series Noire) in someones pocket. 15/16 IPS was on the slow speed version of this. It was 1/8" tape width though. Beautiful machines. The body was/is milled out of a brick of Aluminium (English!). This machine was commissioned by Nixon for the CIA. Look at the thread for which format are you listening to now. Go to page 19. My Nagra SN is there.
Hope this helps.
Cheers.
GPS16
