Resistors in crossovers
Pnstafford
Hello friends.
Rebuilding the crossovers in a pair of infinity column ii's. One resistor is valued at 9.4ohm. I cannot find a replacement with the same value.
Closest I can find is 9.1.
Would that be acceptable?
Or do I look to combine 2 4.7's together?
Thanks y'all.
A 9.1 resistor is still within 5% of your original value. I'd say it would be acceptable to use. Though, 2 series 4.7 Ohm resistors works too, if you have the room?
Got room to series a couple together.
It's just odd the 9.4 is so hard to find. I was directed to ebay for some NOS ones.
Kinda wanted to get some higher quality components in there.
Hello friends.
Thanks y'all.
Is 9.4 a spec'd value or is that a measured value of say a 10 ohm resistor with tolerance?
