Restoring a Sansui 4000
bubhardy
AK Subscriber
I picked up this Sansui 4000 about a month ago.
It works OK, but has the usual-dirty pots and switches, some lights out. Topside, it needs a good cleaning, too. The bottom side is fairly clean, so no photos of it, for now.
I pulled the driver board cover, and removed the two F-1150 driver boards.
Two mini F-1040s!
Complete with Sansui glue holding the diode on top of TR805!
So, tomorrow, I am going to start vacuuming up all that dust, and rebuild these driver boards. I’ll look into doing the F-6013 Skippy mod. TR805 is 2SC708A.
Oh, and it looks like some bits of glue got onto the rotor plates and end stop of one of the variable capacitor sections.
Lots of cleanup to do.
When I said “the F-1040 Skippy mod”, I meant I would be looking into the same SORT of modification.
I haven’t compared the schematics for both boards yet-that will be today.
But, seeing a very similar physical setup, the diode thermally connected to TR805, I am assuming a similar circuit.
I’ll be checking it out!
Rebuilding my second, a joy to work on compared to a 5000.
The 4000 is pretty busy on the back side of the front face plate, with all the wiring for the lamps, and that spring to keep the dial pointer wires from snagging.
Otherwise, it looks like the boards will be fairly easy to access.
Cleaning out all of the dust is going to require a lot of disassembly, though!
A worthy project indeed. This is the first I've seen the inner workings of a 4000, and am quite surprised to see the driver boards are pluggable cards, as the 5000 driver boards are hard wired.
That IS odd, isn’t it?
Maybe the 5000 design was initiated before the engineers started using edge connectors in their chassis?
I do know that, over the years, I’ve heard a lot of guys complain about edge connectors and contact issues.
So I was surprised to see them in the X0X0 and QRX receivers, along with the 4000.
Maybe Sansui used them in units where they anticipated higher build volume, to speed up production?
I'm pretty certain the 4000 was developed and built entirely after the 5000, so it is a newer design, just made to resemble it's older sibling in styling. Sansui was already doing pluggable cards by 70/71, while the 5000 dated to 68. The A and X variants of the 5000 were only minimal updates over the original, so never saw the implementation of pluggable driver boards.
In the 1969 catalog/brochure the 4000 is not listed yet the 5000, 3000A, 2000, 1000A are all there.
This leads me to believe the 4000 came after.
Thanks, Moefuzz and Sansuiman!
It makes sense-so rare in the Sansui world!
It is so difficult to make sense of the lines of gear sometimes, and remember how, for example, the AU-999 came before the AU-888, etc.
And, I'm sure that, once the factory lines were humming with 5000 production, there was NO WAY they were going to allow something like adding these connectors, and the redesigned driver boards for them, to disrupt that.
Companies HATE that!
The 2000A/X have a plug in driver card. My 2000A is from Feb 1970. The 4000 I believe was the replacement for the problematical 3000 series which had probably established a reputation in the market for blowing up and frying woofers. There is a 3500 model mixed in there but those seem to be rare. My 3000A was built June 1969 so late in their run, tuner board different than what is in service manual.
I think that the 2000, 4000, and 5000 also share the same set of knobs.I know that the 3000 has different knobs.
Today, I rebuilt both of the F-1150 driver boards for my 4000.
The heat sinks on those transistors are nice! The fins have ridges to increase their surface area. You just don’t see heat sinks like this anymore!
After doing a bunch of reading, I decided to stick with the original TR803-805-807 and STV-3 diodes. The diodes tested fine, with a Vf=1.5V. Kevzep wrote that he’s never found a bad one. I know that I mentioned above a “Skippy124-like” mod, but after reading some posts and looking at the schematic, we’re talking apples and oranges.
So, I took the diodes off of the TR-805s, and scraped the glue off everything. Lacquer thinner hardly would touch it! I stripped some red and black insulation from some 18AWG wire, and used it to cover the anode (red) and cathode (black) leads. The original clear and blue sleeving had glue up inside of it. I preset the “output adjust” trimmers to about the same position as the originals, and the bias trimmers to min.
The old trimmers were wacky! Here they are-
The two on the left are VR801. They read about 85-86K, end to end. But CCW-W I got 26K on one and 21K on the other. W-CW I got 75K and 83K. Weird. The trimmer is supposed to be 100K. Same thing with the bias trimmers. In fact, one bias trimmer read higher from W-CW than end to end-4.5K vs. 3.9K! I’m chalking it up to them being those old open trimmers and 50 years of dust and grime. These kind of trimmers were the absolute cheapest ones available at that time. I didn’t bother to try cleaning them, but I would have liked to have had resistance readings that add up right.
And this was across a Fluke 87 III and an 87 V-not some crappy Harbor Freight DMM.
So the driver boards are back in place, and tomorrow, I’ll fire it up on the DBT and check the bias. If all goes well, AC mains and set bias, after warming up for 15-20 mins.
I’ll be recapping the rest of the boards after this. Saving the chassis mounted caps for last!
moefuzz, your Peanuts cartoon made me chuckle!
With both driver boards recapped, and TR801 replaced (2SC458 with KSA1845), I fired her up on the DBT, then after a good DBT test, plugged it directly into the AC line.
I checked the bias-I could only get 5 mA max on either board.
I checked the PS-70VDC, but 37V at the midpoint.
So I cleaned the edge connectors-got up to 10 mA on one, but now, 6 mA max on the other.
After reading the posts on milo63’s 4000 with a driver board problem, I checked all of the resistors-all measured fine.
I tried swapping the boards-same result.
Then, I discovered that the foil on one board on the base lead of TR807 had come loose-still soldered, trace intact though.
So, I used a trimmed lead to go between the base lead of TR807 to the closest lead on that trace, to help stabilize it.
Now I get full bias on that channel, but the other channel still only gets to 10 mA max.
Still 37V at the midpoint on that channel.
So today, I am going to replace TR807 with BD139, and TR809 with BD140 on that board and see if this helps.
I read that KSC2690/KSA1220 are the recommended replacements, but the BD pair should work, too.
I have KSC2690, but not KSA1220, and no mainline distributors (Mouser, Digikey, Newark, etc.) seem to have KSA1220 in stock-but I do have BD139/140.
I’ll give them a try.
I’m getting decent sound through headphones, though.
The only way that I can get the correct bias current (10-15 mA at room temp below 25C) is to turn up VR801, which causes the midpoint voltage to drop from about 37V to about 24V.
I’m beginning to wonder if one of the output transistors on that channel is an issue?
Or the output cap?
Any ideas, guys?
OK, likely solved the mystery.
Checked the output transistors-2x2SD213 in the right channel, and 2x2SC1402 in the problematic left channel.
The left is the one that won’t bias properly.
I have 4 MJ21196G that I can put in-kinda overkill, but I have ‘em, so I might as well, to see if this is the issue.
Got the 4000 on the bench, ready to change out those output transistors.
It’s a bit cleaner now, but needs a good wipe down with a damp rag.
But it IS a repair friendly design-super easy to get at these transistors.
Sure hope this helps with the bias issue.
HELP!
After replacing the output transistors, I still can’t get more than about 6 mA bias current. I have rebuilt the F-1150 driver boards.
Driver board replacements-
TR801-was 2SC458, is KSC1845
TR803 was 2SC708, is 2SC708 (left original with D801 clipped on top).
TR805-was 2SC708, is BD139
TR807-was 2SA537, is BD140
C801- Wima MKP4 0.22uF, 250V
C803-Nichicon UKA 220uF, 35V
C805-Nichicon UPW 100uF, 50V
C807-Nichicon UKT 3.3uF, 50V
C811-Nichicon UKZ 100uF, 50V
C813-Nichicon UKA 100uF, 25V
C815-Würth 0.1uF, 160V polypropylene
C819-Nichicon UKT 10uF, 50V
Both STV-3 diodes measure good-1.5V Vf.
Also, replaced both output caps with Nichicon LKG 4700uF, 80V.
Power supply measures 66VDC, output from protector board to driver board is 64VDC, voltage at the midpoint (between R835, C817, TR811, and terminal 8G on the driver boards) is 33VDC.
The only apparent thing that I can seem to do to increase bias current is to adjust VR801 upwards.
But the output adjustment is supposed to be set at minimum for the bias adjustment.
Is the bias current adj-output adjust an iterative thing?
Several of the boards in this thing have soldering issues. Specifically, F-1185, F-1038, and F-1214.
Here is an example-
Up close. Look how grainy the soldering is.
When I hit these with a hot iron, the solder bubbles. Something in the old solder seems to be outgassing, but it doesn’t appear to be flux. I add some new solder, they bubble, and go cold. I have to keep adding new solder, letting it cool, and over again, until I get a decent solder joint. It takes several passes on each connection. I’ve never seen solder behave like this!
So, here’s where I’m at-
I’ve replaced the output caps, the main PS filter caps, a couple of PS elecs on F-1214, and a few films/elecs on F-1038, which the SM calls “F-10382”. The board says F-1038.
Also, there is an error in all of the F1050 schematics in the AK database and on hifiengine. In the left channel F-1150 (top board), VR801 wiper and C811 negative, connect to the midpoint common. In the right channel F-1150, they are shown as only connecting together, and not also, the midpoint. An exam of the boards confirms that the left channel schematic is correct.
I’m using good solder, moefuzz-Kester 63/37 30mil RA flux.
No more than 2 years old.
I have had to reflow a ton of solder joints.
I’ve found that whatever it is that’s outgassing goes away, but I had to make 3-4 passes on each joint.
But I wasn’t dwelling on any one, and I did areas at a time.
I should have taken a pic to show-oh, well!
I gave this some thought, and I came to the conclusion that when some of the boards in this receiver were made, there must have been an issue with the solder bath lines that these were processed through.
I would imagine that Sansui used solder baths for their boards.
These are NOT built by hand!
I’ve seen too many defects of the sort that indicate this.
I found a number of loops of leads on the bottom of the two RF boards, sticking up from the board, but soldered into a connection.
Not shorting against anything.
I removed all that I saw.
So the two RF boards and the audio input board were like this.
Coincidentally, only these three boards have soldermask.
All the rest of the boards in this thing have bare board and copper.
And none had the solder issue.
So now, I recapped it, replaced all of the low level AF section transistors, cleaned pots/switches-and now I’ve lost the output.
I don’t think it’s in protection mode-the protection bulb is off, and has no voltage across it.
I’ve already done a visual-no transistors in wrong.
I replaced a bunch of 2SC458 and 2SC871 with KSC1845.
I’ll have to look over the electrolytics for a polarity reversal still.
I kinda doubt that, because nothing’s popped, and this has no bipolars.
But the tuner still works, and it passes DBT, and it still won’t bias over 6 mA.
So, I’ve got a built-in signal source.
I’ll get out my scope and find the issue(s).
I can’t WAIT to see what I find!
But I have some paying work to do, so I have to put it away for a few days.
Hi Bub, please excuse my bad accent...
Very interesting picture and pretty obvious there has been a long term reaction
with the original fluxes and solder. Perhaps the original flux was not cleaned
and it was corrosive and chemically scorched the legs of the components?
To be honest, I am better with a welder than I am a with a solder iron
and I can even twist a tire iron in the alley after dark but ..
..but looking at this pic all I see is holes, corroded legs and a lack of fusion for whatever reason.
Whatever that used to be, now it is not a soldered joint
- and at least some of these contacts could be emitting high frequency intermittent noise/squeal
while still passing some signal.
Also, perhaps the solder you are using is not the best?? Just thinking outside the box..
Shiit solder and tree hugger solder is not good solder and will fight you even on good clean boards - this, regardless of old boards and reflowing solder - it will fight you.
Lastly, is something on the board like residue from a unknown cleaner product
that is screwing with your solders ability to flux? Wash the board of residues
regardless if it feels clean, all those holes may contain something your chosen solder can't
deal with and is not compatible for whatever reason.
and perhaps the corrosion on the legs is to thick over and above incompatible solder and flux??
She IS a comely lass! :naughty::banana:
OK, I am at a point where I can go no further, without help.
Bias is maxxed out at 6mA, no more.
Output adjustment, maxxed out on both channels, is 33V on one, 31.5 on the other.
The unregulated PS Voltage is about 70V, with the driver boards in, 72-73V with them out.
So, I decided to scope the output, and see what the output adjustment is doing.
I connected an 8 Ohm 60W non inductive load to the left channel out, 1kHz., 200mV pk-pk sine wave into both auxiliary inputs, and powered on.
Started to turn up the volume.
Scope trace looked great, until I hit about 10 o’clock.
It went into oscillation, so I killed the power immediately.
Without a load, it doesn’t oscillate.
So, it’s a big heavy headphone amp, at this point.
Anyone got any suggestions on where to look, or what to look at next?
I know this doesn't help but don't give up, put it aside for a bit if you have to but it's a puzzle that you can't quit.
Somewhere in that jigsaw puzzle there is a piece that doesn't fit, with enough tenacity and profanity you'll find it.
Matt
I've got a few "unsolvable Sudokus" on the shelf but one by one they're getting done.
Quitting isn't an option.
