Hey guys, first time poster here. I've been using my dad's old "Prophile" speakers that he bought new from a local shop in the 80s. Here's an older thread I found discussing them: https://audiokarma.org/forums/index.php?threads/jsg-prophile-speakers-anyone-heard-of-them.648356/
I'd like to restore these speakers and was hoping to get some help from the experts on here. Here are some images to go along with the questions below: https://imgur.com/a/6GizNdU
- I'd like to first replace the capacitors. There are three wired in parallel - 4., .22 and .47 uF.
- Is there a reason why they didn't just use a 4.7 uF here? Can I just buy a 4.7 uF with an equal voltage rating and be ok?
- Is there a decent brand of caps I should use for this application? Ideally I'd like to spend <$50 for both speakers' caps combined, but would spend more if I knew it was going to make a substantial difference or increase lifetime substantially.
- When I pulled out the speakers I noticed a ton of sound isolation foam that had degraded and fell apart within the cabinets. I threw out all the old foam. Do I need to replace the foam here? Is there a certain foam I should be using or can I just grab whatever sound isolation material they sell at the local music store?
- There's a red coiled component wrapped in plastic as part of the circuit. Maybe an inductor? Do I need to replace this?
- Is there any reason to replace the speakers themselves?
- Does it look like I need to refoam the speakers?
- There's some sort of knob/potentiometer on the speaker terminals (where you connect the speaker wire). What is the function of these knobs?
