Ugh ... sigh, well I'll say you are already doing much better than me with my first attempt at tube amp repair!
It's a long story but to make it brief, I did correctly diagnose, the "Original" issue with my Heathkit AA 40 tube amp. It had a bad surgisitor, so I sent it all the way cross country on a pallet in a wooden crate filled with inst-pack. You could have dropped it off a truck and it would have been fine. That guy/company were tools, they wanted to do some mickey mouse, add a switch by drilling holes in the front. So I said screw that sent it back!! And I got it back dented, somehow!?? Not bad but still ... annoying!
Fine then ... I'll fix it myself, well in my defense this was pre internet as it is today, so late 90's?? I went with the "
Blind Monkey with a screwdriver approach???" (not recommend!) I must have, flipped it over, on the bench on a stand to hold it above the tubes, jumpered the surgistor, powered it up ... and then proceeded to poke around on the inside with a screwdriver!! Yeah ... that "Did Not" work out so well!!
There was a loud bang, a bright flash, smoke and then nothing ... and my next thought ... after finding myself, still alive and unharmed ... was well that could not have been good??? After that I uh bought the manual! I'm pretty sure before that all it needed was caps and a CL 90 to replace the surgistor. Now it most likely needs new transformers ... also??
But hey you know ... live and learn (Hopefully) if your lucky! So you know, I sucked at Tube Amp repair but my "Plan B," kicked into gear, if your gonna do stupid crap ... it's better to be lucky than good."
But hey you know there is also uh ..."learn from others!" Most likely that is a much better, safer and uh less expensive option! And I do have an all original tube amp in my Maggie Console ... that I have not uh screwed with! A dim bulb tester and a bit more common sense this time, will be my first steps!
So yes ... your doing much better than I did already by far.
