bouldersound
I finally got tired of looking at my Sony TC-388-4 sitting unused in the closet. I bought it as semi-working in a second hand store and never got around to making it work. I started to tinker with it one night and before I knew it I had the front panels off and the supply hub out. The problem had been that the supply hub brake didn't let go when playing, so there was way too much tension on the tape while playing. It turns out there was some grunge left by one of the pads on the hub, which caught on the brake pad and caused it to grab when it should have let the hub turn. The other issue was the rubber idler between the motor shaft and the capstan flywheel. It had developed a shiny smooth surface that didn't gain much traction on the metal wheels it interfaced with. It's a work in progress, but it does seem to be working for now.
