Acespaceman
Can you expand on this a little bit?The Zero 100 arm bearings aren't up to the DL 103. Not a good match.
Too bad as the match would seem good otherwise. I've tried most of the various Shures mentioned on a couple of tables in past and found the sound just too "plonky" to be realistic to my ears. Ok if the goal were a "vintage analogue" sound I suppose and I'm sure there are plenty who would disagree with me. YMMV What about a Nagoaka MP-10? I haven't had mine mounted for a long time and it still recall a bit of that "plonkiness" in the sound, but at least I have one kicking around in good orderThe Zero 100 arm bearings aren't up to the DL 103. Not a good match.
I think the OP is referring to a Pickering V-15 here as Malden mentioned its low profile was suitable for correct VTA.
After looking a little closer at my cart stash, it turns out its actually an XV-15. Still I have no stylus for it at the moment. Not even sure where this cart came from, but my meter says the coils are good.
I do also have a Stanton 500. Which stylus choice would be suitable for the application?Yes, the Pickering V 15 is an ideal match to the tonearm, and you can even use the XV 15 with the medium tracking stylus options. The V 15 line and the Stanton 500 sisters are good Garrard friendly options for the Zero 100.
The Zero 100 tonearm bearings are not able to dissipate the energy of a high mass MC. And the changer mechanism is not ideal for an MC either. The Zero 100 tonearm bearings are not the equivalent of a high mass MC friendly manual tonearm with substantial bearings. This Zero concept would be better executed with today's materials and engineering knowledge as a manual arm.
If you want to try a more compliant cartridge you can modify the arm a bit. Removing the adjusting weight that sits behind the headshell and just doing your tracking force adjustments with the counterweight at the back will let it run a more compliant cartridge than would function well otherwise. I did that to mine a while ago. I've considered un-doing it but I lost the spring that sits on top of the slider weight so I'd need to come up with a piece of spring steel before returning it to stock.
It can't be the mass of a DL-103 that would be a problem as at 8.5g many of the carts being suggested are as heavy or heavier. The aluminum cantilever is as robust as any and I would have thought the conical diamond would have been a good choice and optimum VTA is right where one would want it to be. What else would make it problematic? Not quibbling, just curious....The Zero 100 tonearm bearings are not able to dissipate the energy of a high mass MC. And the changer mechanism is not ideal for an MC either. The Zero 100 tonearm bearings are not the equivalent of a high mass MC friendly manual tonearm with substantial bearings. This Zero concept would be better executed with today's materials and engineering knowledge as a manual arm.
Happy to see this thread and kudos to the OP for starting it. I always felt that the Zero 100 was overly criticized and could be made into a nice turntable with careful consideration for cartridge and stylus selection.
It's a beautiful turntable and I appreciate Garrard's out of the box thinking to put out a panto-graphic arm when no one else was doing it. Despite the Plessey financial R&D handicaps Garrard engineers faced, they put out a more-than serviceable turntable.
Here are a few links from the TNT site that offer tips to make the most of the Zero 100
Garrard Zero 100 SB turntable
History, availability and restoration
Listening test
Various Tweaks
Here was mine. It now sits in my father's den.
A while back I posted a thread about modifiying the tangential arm/bushings for reduced slop in the mechanism. It was a successful project that showed a small, but noticeable improvement in the sound, and a very noticeable improvement in physical slop in the arm.
Can you post the link to this thread?
Listening test
Various Tweaks
