jjbunn
Member
This TA-3A has no sound: it doesn't come out of protection - power up shows an amber led then shortly after a green flashing led.
Having read lots of material on this forum about the TA-3 I started off by replacing R309L and R309R - the existing 22kOhm resistors were different wattage, so maybe someone has been inside this amp before me, although you wouldn't guess it judging by all the dust! The lower wattage R309R measured a bit high. But I replaced them both with 2W types.
I also found an unsoldered capacitor leg nearby to R309L, so I soldered it.
No change on power up.
Then I removed all the connectors to the logic board. In that state, the amp powered up to solid green led. I replaced all the connectors one by one until the amp wouldn't power up properly.
It turned out that CN 1 was the cause: with it disconnected the unit powers up to solid green led. But there is still no sound from speakers or headphones. My understanding is that CN 1 is related to auto power control, but I'm not sure.
I checked the onboard battery, and it is essentially dead, so I have a replacement on hand, just waiting for the socket to come in (I'm not going to try soldering to the battery itself).
I spotted something odd on the logic board - see photo attached. It's CN 12, which seems to have had a wire soldered between the pins, which is now broken/disconnected. Should CN 12 pins be shorted together?
Thanks for any advice/tips/suggestions!
