justinbroken
Hello,
I have a Pioneer SX-3800 that I am restoring. It was DOA and was a victim from a cracked transistor socket.
I first replaced the sockets with phoenix connectors. I then replaced all the caps and transistors on the power supply board and replaced 3 resistors and 1 transistor that tested bad on the power amp board. Also did a thorough deoxit treatment. The four output transistors were not damaged at least!
I am able to set the DC balance and idle current according to the service manual and upon my initial full power testing all is good.
It was not until I turned up the volume very loud to where it almost maxes out the display meters that the volume lowers equally on both channels. This occurs with or without speakers connected/selected. I by-passed the pre-amp with a different source and it does the same audio drop too...as well as if speaker A or B is engaged or not.
Pin 22 & 23 on the power amp board read normal until I hit that loud volume threshold and then the readings jump back and forth and up and down .mvs to .vs.
Since both channels seem to be equally affected should I concentrate on the power supply? Or is there an area on the power amp that equally affects both channels that I should troubleshoot? What am I missing?
I appreciate any suggestion or guidance offered.
