AngelAT
Well-Known Member
I am experienced working on solid state units and recently started expanding my portfolio with tubes.
I bought a Revox model 40 stereo amp. Seller said it was not turning anymore. It came to be the power switch - was jammed and not moving properly. This was an easy fix.
Then a resistor for the phono tube was split in two. This was also replaced.
One of the channels (left) was intermittent- came out that the banana binding post was not making proper contact. Also the resistors looked a bit dodgy so also replaced them.
Now my main problem: the amp starts to oscillate after a few minutes. Came out that it was due to one pair of the output tubes. When switching the pairs the problem moved to the other channel.
My question is could this oscillation be caused by a defect component or is it just the tubes?
I have already ordered a new set of tubes but would like to fix everything before installing the tubes. The problem is this unit has a strange design and all components are in a circle below the tubes. And I don’t want to mess around unless necessary.
Are there any particular components that require attention. Someone has worked and one of the rectifiers was replaced.
Thanks in advance!
Thanks in advance!
