IamSpartacus
I'm in the process of setting up a new sound room and I've run into a problem I've never had before....
I just purchased a Yamaha A-S701 amp after 50 years of using an older Yamaha CA-810
I'll be switching between some vintage DCM Time Frame speakers (8ohm) and a pair of Magnapan LRS+ speakers (4ohm)... and until I can afford the subs I do want... (2) polk powered subs.
In the past and with an older CA-810 Yamaha amp, I ran the two powered subs directly to the amp.. then ran speakers wires off the 8 ohm subs to the 8ohm DCM speakers.. which drops the ohmage ('m told) to 4 ohms.. It's worked just fine... Even when I was using (4) tower speakers and the same two subs... All was well... No idea what that did to the ohmage..
Looking trough the new Yamaha manual, it says to NEVER connect subs this way.... Instead... this is what it says.. (pasted below) ..
I'll add... My end game plan is to connect ALL my speakers to one of those Monster Speaker Junction boxes and just pick and choose which speakers I want to listen to with or without the subs... Right now I'm just wondering if I should stop connecting the subs like I have for decades and follow the advice in the new manual and buy some kind of "splitter" and use the dedicated sub port?
Opinions? I'd hate to blow a new amp with simple ignorance... Somebody educate me...
How to Connect Subwoofers Safely
- Active (Powered) Subwoofers: If your two subwoofers have their own built-in amplifiers, you should not wire them to the speaker terminals. Instead, use the dedicated line-level Subwoofer Out RCA jack on the back of the Yamaha A-S701 Integrated Amplifier (using a Y-splitter if needed for two subs). This completely bypasses the amplifier's speaker load impedance.
