Edit: Solved, see post #7.
Here's a real humdinger. Yesterday, I turned on my NAD 7155, tuned into a local FM station, and left it on in the background. I stepped outside for a second, and come back in, and all I hear is static. It wouldn't pick up any stations at all ... I hit the FM search button and it would scroll up and down and never lock onto a station. But I switched to AUX input, and that worked fine.
So I hopped online for a little while, did some searching, and surmised it must be a loose component causing the FM to drop. This made sense, since I had to repair a couple loose solder joints in the power supply. I removed the case and turned it back on, intending to wiggle stuff until the FM reception snapped back. But, lo and behold, FM came in loud and clear from the moment I turned it back on.
Today, I left the case off and left it tuned into an FM station all day, listening and waiting for it to lose reception. I planned at that point to check for anything loose or hot, or somehow try to isolate the problem component. However, all day it played great, FM loud and strong! So I say huh, weird, and put the case back on.
But within 5 minutes of putting the case on, it suddenly turns back into static! So I pull it back off, feel around for hot transistors, even freeze spray them all with a duster can to cool them back off. But it won't pick up the FM station again! I turn it off, wait another 30 minutes or so, and turn it back on. Ta-da, FM is back.
I wasn't sure if the case thing was coincidence, so I let FM play for 5 minutes or so, and put the case back on. Soon thereafter, static again. Weird!!!
The question now is, hmm, how to diagnose. I figure it may be an issue with a transistor that is on the verge of failing, and when the case is on, gets just too warm and fails. What's strange is that even if I take the case back off and wait a while, it'll never tune back in unless I turn it off and let it sit for a little while.
I'd love to know if anyone has experienced anything like this before! And if my heating-failing-transistor theory makes sense or not. I'd love to fix it!
