Right channel doesn't work only when it's set to stereo
lnette
Hello.
I bought a H/K PM660 not too long ago and I have been enjoying them ever since I got them fixed. Over the last few days though I noticed something peculiar. The right channel wouldn't work when it's set to stereo. When I set it to reverse, the right channel works, the left channel does not. When it's set to mono, both channels work.
My first guess is that the right channel on my amp does not work, and mono works only because the left channel is is processed to both left and right speakers.
And I don't know if this will help, but ever since I got my amp fixed, whenever I turn on the amp, the speakers made a very audible and loud "click sound," when that click was barely audible before I took it in for repair.
Is there anything I can do to check to see if the amp is repaird correctly?
Thank you
Yeah, I'd agree with that. Probably power amp has fault. Ideally an oscilloscope or audio probe is required to track it down.
Outside chance it's a dirty switch, you could try slightly rocking that mono/stereo switch back and forth and note any change.
A healthy/loud click is good. Maybe the tech replaced the protection relay or the timing cap, either way no issue.
Nono, OP said the problem switches sides when speaker are reversed. That means the Power amps are both good, and the problem resides somewhere before the stereo switch.
  • Like
Reactions: mbz
does this mean it's a faulty switch or a faulty board, and not the power amp itself?
yep, my bad, problem with google translate...
If the click you are talking about is audio coming through the speakers, rather than just a mechanical click coming from the chassis, it usually means that the DC balance at the output is not at 0 volts like it should be. To test put a set of voltmeter leads on the speaker output connections and see if the voltage exceeds 0 (+ or -10 mv). It it does, it needs adjustment or amp board repair. should be 0v
As far as the 1 channel, I would think a dirty switch, bad connection, or bad cap or other component in the tione amp/control amp section.
Thanks for the explanation! I'll make sure to get a multimeter to make sure that the volatages are good.
It means it's not the power amps. From there on it's anyone's guess at this point. But I'd go with the tip of cleaning pod's and switches first. You can find an elaborate 'howto' right here.
https://www.google.com/url?sa=t&source=web&rct=j&url=https://audiokarma.org/forums/index.php?threads/the-idiots-guide-to-using-deoxit-revisited.207005/&ved=2ahUKEwjD5L267sHtAhVRUhoKHcHYA1cQFjAAegQIAxAC&usg=AOvVaw3ep4CkYidTUR9XDzai7EKA
Thanks! I'll try this and let you know how it goes
so I ordered what I needed online, but the package got lost (sigh), and they're sending a replacement package.
but it seems like the stereo seems to be working again - so I think it was just a problem with the swtich not relaying the signal properly.
I'll update you guys when I get the package and service the amp, but in the meantime, I wanted to ask a couple more questions regarding the general maintenance of the amp, like how often I should use the DeOxit, and if it's okay to leave the amp on, even when nothing is playing, or should I turn it off every time I'm not using it, etc.
I'm still new to this world so I apologize if these questions are basic, but I want to take care of the amp because I really like it.
Also, thank you guys all for your help!
Arrr, yeh it happens. Think of it as suspense..
Great! Give it a nice place: stable, maybe bit of dust protection overhead and with ample opportunity to ventilate.
If all is well, you commonly use the amp and don't live in a permanent dust storm you should be able to do years without. On the other hand: once a particular pot or switch has some wear on it, it might play up every now and then. The amp will let you know.
As for leaving it on while not in use: better not, for say more then 10 minutes. It's not wearing out that much or anything, but rather a waste of energy.
thank you for your help!
I've read somewhere on this forum that it wears down on the components if you turn it on and off too much, but I guess it was meant to do that, but I just wanted to make sure
