sKiZo
Hates received: 92644 43.20°N 85.50°W
BIG difference between ripping and playing. The high end transport won't usually need as much error correction, have a better DAC to convert the 1's and 0's from the disk, and should improve the "on the fly" direct playback.
As mentioned, your el cheepo ripping deck should do a fine job of ripping the disk to FLAC - it may just take longer due to more read errors, buffer fartz, and whatever. There, a lot depends on the software you use, as that's what verifies you have an accurate rip before writing the final version. Good news, one of the best packages out there (Exact Audio Copy) is FREE! It's good enough that the "light" version is built into a lot of front end server software like jRiver Media Center.
Little tip - use the default setting of "5" for ripping to FLAC. Only difference is file size, but not a lot, and it takes quite a bit longer to do the rips using higher settings - There's no audible difference as a result.
