Ripping CD's
What CD Ripper do you use
  • iTunes
    Votes: 11 21.6%
  • Exact Audio Copy
    Votes: 27 52.9%
  • dbPoweramp
    Votes: 14 27.5%
  • Total voters
    51
I only rarely use PC's, otherwise I would have been using Exact Audio Copy long ago.....I was not aware of such a thing on Mac. I've long used iTunes for ripping.
Now I've found something which also uses the same master database of user file information as Exact Audio Copy on Windows....dbPoweramp. ... I'm using the free version today but plan to purchase the single use version for $39.... It rips straight to lossless FLAC....
Here's hoping the OP will come back and clarify what he/she is actually using and trying to accomplish.
My take (based on above) is they are using a Mac and if I'm not mistaken EAC doesn't work on a Mac and if converting to FLAC as has been suggested then they would need a FLAC music player seeing as iTunes won't play them.
Just an FYI to anyone thinking of posting or offering suggestions the OP has posted a total of 3 times since 2016, this thread being one of them so I doubt he will be replying anytime soon.
So save your suggestions
I only rarely use PC's, otherwise I would have been using Exact Audio Copy long ago. It compares CD rips against a master database, and can tell you when rips are exactly correct (or at least matching hundreds of other users).
I was not aware of such a thing on Mac. I've long used iTunes for ripping. I check the "Use Error Correction" box in preferences, and rip twice, then compare the files. Faulty files that sound bad always seem to differ from one another. But for such a longish time I had not seen any errors, I had switched to just ripping once. Now I find on a lot of CD's, especially ones I got from Alan, they rip with audible skips (even with the "Use Error Correction"). The iTunes ripping is something like a "college try," if it doesn't get it after a few times it quits and just gives you some kind of guess. I've also taken to examining the CD's carefully under a strong lite first and cleaning obvious dirt with a soft cloth and RO water. But often there are scratches or defects that can't be cleaned, and often there are errors in the CD rips when there is no visible issue. I wonder if some of these discs were made not to rip correctly.
Now I've found something which also uses the same master database of user file information as Exact Audio Copy on Windows. It's the program dbPoweramp. It seems to fix many of the discs I was getting different reads from on iTunes, and certifies them as accurate. I'm using the free version today but plan to purchase the single use version for $39. It seems to try much harder than iTunes, possibly using error codes from the CD drive. It really slows down on bad discs, otherwise very fast. It rips straight to lossless FLAC, which save half the space.
I know there are many many rippers, but few it seems compare song file checksums against a master online database.
I use Nero. That burning software has been impressive. The key is to get a great DVD/CD burner (which are becoming very hard to find). I have a Plextor in my living-room PC which I also use as a music server. The key, I believe for ripping CDs is to burn them at a moderate speed. Instead of 40x or more, I use no more than 8x. With that slower speed, I have experienced very few blemishes or skips. :)
I licensed the full dbpoweramp product line in 2013, have updated it a few times since and have never had any issues getting good CD rips with it.
Back, way back, @ the dawn of the CD ripping era -- circa 1492 -- I used EAC (Exact Audio Copy) exclusively.... until the last time I ripped a CD -- circa 2010.
If Want to copy a CD I place the CD in my Mcintosh Player then using an already connected optical cable sending the signal to the Marantz professional CD recorder. Get out the remotes and push play and record and I'm all done. Or down load the CD with my external burner drive. Then play the stored music back from the SSD and burn a copy on the external burner. Computer is faster. But the CD recorder is easier.
With EAC it pays to run the auto setup during the install. It offers the option of running a speed test on the designated drive. It will then always default to that speed unless told not to.
I can't help with regards to OS X, but on Windows, every computer with Windows XP or newer includes Windows Media Player built-in. Windows Media Player can rip to WMA Lossless (as well as MP3 and other formats). That means, when using any Windows PC made in the last 20 years (sometimes even older), you can pop a CD in the drive and make a lossless rip. All without installing any additional software. You could transcode the WMA Lossless files to FLAC later on but there is really no need.
EAC here but new CDs to rip are few and far between. Use the error check and save as FLACs to my harddrive then save on Sony HAP-Z1ES and HAP-S1.
Once you work through the user interface a few times and get how it works, it's slow but great.
I really like Nero`s burn software that was included free with tower form factor LG brand BR/DVD/CD optical burner/players that I connect externally via a SATA to USB 3 converter/adaptor w/it`s external wall wart PS have served me very well for close to 10 yrs.
I found experimentally the use of the externally connected optical burners to have been providing glitch free burns at much higher speeds (much less time) than the OEM built in internal optical units included with any of my 4 of which 1 is a player, laptops that I use to store & backup all my music..
I believe the free/included is the Nero 12 version I`m currently using came with the last internal style desktop form factor LG units I bought some 6 or more yrs. back inexpensively.
FWIW, I have successfully WAV. ripped all my CDs minus SACDs, both new & old with no problems using MS`s OS Win. XP/7/10 WMP if the CDs are not in too bad shape, which my personal ones are not, but some borrowed from friend`s CDs have needed to be, not only cleaned with my ~ 25 yr. old Discwasher brand manual crank CD/DVD/BR cleaner, but in some cases the borrowed CD has to be polished with my battery operated & very effective polisher unit system for a skip/glitch free rip/burn after cleaning.
If the borrowed CD is un-abled to be polished up for skipless/glitch free burn/rip, then I try to go find it`s replacement on line and purchase it if I really want that Band`s album.
I tried to use EAC some time back and found it`s software too complicated & takes to long repairing heavily scratched CDs for my simple ripping needs.
I`m quite happy with my burning/ripping software/methods, & see no reason to change.
Ciao
Ciao
I like to use Kodak "Gold" CD-Rs. Those have always performed very well, as have the increasingly difficult (if not nearly impossible) to find Maxell CDR-PRO. Those are actually my favorites. Memorex CD-Rs, Ritdata, and the rest you can disregard as they are junk. TDK isn't bad, but Kodak Gold is the very best :) I never use a CD cleaner, but the version of Nero I have has a function where it very slowly scans the CD... I think it is like 2 or 4x, and extrapolates any missing data. This seems to work really well. I have not found a CD yet, where it has not produced acceptable, in not even stellar, results. :)
Yet, quite frankly, with the very reasonable cost of CDs today (especially on Ebay) if I get hold of one that is too terribly scratched, I will just order another. ;):angel:
Ciao
The only remotely complicated thing about EAC is the initial setup. Once setup is done properly, insert disk, start EAC and write the files. When setup properly EAC finds the metadata including cover art. Easy peasy.
EAC is the only software I'm aware of that makes bit perfect copies. When EAC encounters scratched or defective CD's it can be very slow reading a disk. That's because of the bit perfect copying.
When I come across a CD or track that's in such really bad condition it causes EAC to balk I use Freac (Free Audio Converter). As always FLAC is my storage medium of choice.
in the linux world, anything that uses cdparanoia makes bit perfect copies. :beerchug:
EAC is the best in the windows world, at least it was back when I used windows.
the length of time it takes to rip a cd is entirely dependent upon how damaged the cd is and how many sector retries are required... I have had a cd take over an hour to rip before, but most of my cd's were/are in perfect condition, so rips(and conversions) take a couple minutes max.
Funny, back in the early 00s, converting a wav to an mp3 could take hours, so usually I'd queue up a few and let the computer spend all night churning away to convert, now the conversion is done nearly as fast as the original rip. Ain't technology grand?
This is the secret to the active AI in Nero it seems. If a CD is damaged through scratches, it will had drop-outs. In that case, having a "bit perfect" copy is not desirable. The software seems to extrapolate what it needs to fill into the damaged spaces. :)
:beerchug:
Yes, and also I like being able to with using Nero to pre test (examine) the CD before committing to the burn, thus saving the waste of blank media, especially the more costly archival type gold blanks that I use, for example with MFSL CDs, that I split the purchases with my friend, OMR for my burn copies.
For the well over a decade I`ve been using the various free (included with my purchases of various optical DVD/BR/CD R/P media devices) versions of Nero media software ( 7 ~12) it has never let me down, and is so easy to use for this simple minded old man to easily do what tasks I`ve asked of it.
Hi Bill,
I have been recently using Nero Plantinum (from 2016 or 17). It works great in both Windows 7 and 10. If you go on Apex++ or DC++ you can download a.. well, lets say you can download a "shared" copy from one of your friends there for free. ;) :angel: I have had incredible luck with the Kodak Gold CD-R and DVD-R discs. My favorites though... The Maxell Pro CD-R which are so hard to find now. I have only been able to get them from Ebay.:)
Hi Bill,
Thanks for the Nero Platinum "shared software" info, Dear Lady, I`ll check it out. :beerchug:
Take care & have a great Sunday, Miss Natasha Bell. :hug:
