Ripping Vinyl to Flac
nj pheonix
Lunatic Member
First, I'm a nube to digital high end audio. I like the premise of loading uncompressed music to a server for easy access. My question then, and i imagine someone has toyed with this already. Can you rip vinyl into a flac and end up with the same sound quality on the playback as the original? I've been eyeing a Tascam CDRW900SL, with the belief that i could use it as a DAC and rip my vinyl into flacs. Is this a realistic endeavor or is there something about the limitations of the equipment or technology that i don't understand?
Thanks RH, i was reading some of the material. Would it be fair to say the equipment and software to do it are better and easier to use that older stuff, or it is what it is?
There are many modern hardware and software options for recording and processing. From what I've read it can get rather tedious. I have no first hand experience BTW, my comments are only based on what others have shared.
I have a Rolls VP29 phono pre and a Behringer UCA202 ADC. Audacity installed. I just haven't made the time to actually rip!
I was new to this until about a month ago. The Tascam CDRW 900SL is a fine unit indeed. (I use one). However, it records in redbook (CDA) format only. What you would need to do is get some good quality CDRWs (I suggest Verbatim) and record your vinyl onto one of those then put it into the PC rip it to FLAC directly through MS Media Player. Better suggestion although involves more steps: 1) Record the record using the Tascam, 2) Put CDRW in PC and rip to WAV with the MS Media Player, 3) Rip disc you just created to FLAC using Exact Audio Copy.
I am in the middle of digitizing my vinyl. I am doing the following (I'm somewhat OCD I think): 1) Recording to CDRW using my Tascam CDRW900SL (running TT through Phono Preamp to Tascam, 2) Put in PC and ripping to WAV using MS Media Player, 3) Running through Audacity for any clean up or editing (I generally do click and pop remove and them make sure levels are correct, label the tracks and export to a separate folder. 4) Burn a CD with the WAV files (I also go so far as to make it look as professional as possible with jewel case and everything) 5) Start up EAC, insert disc just created and rip to FLAC, 6) start up MP3tag and tag the FLAC files.
That's just me though, most folks don't like to bother with all that. YMMV
My technique isn't the most audiophile, but I run the audio out of my preamp to a Y cable into the AUX in of my Gen1 Macbook, record in Audacity and then split the files.
It's not studio CD quality but I've got some darn good copies that way. I save my files as WAV, convert to FLAC and burn a Redbook CD (since most of my listening of these is on an actual CD player.) So far I am more than satisfied with the results. Heck, I'm playing a CD of Lupin the Third that I ripped from the Vinyl. It sounds great!
Hang around or read in the turntables forum. A BIG piece of the vinyl playback business is associated with the cartridge and stylus. The importance of the first transducer to touch the record surface can't be overstated. Whatever system you are using to transcribe or rip from vinyl will require knowledge of vinyl playback.
A few of the intricacies are things like matching the cartridge electrical loading from your phono stage to the requirements for the cartridge. If your systems are using say Audio Technica cartridges, your standard 47K is quite acceptable. But, if the cartridge is different, it may pose an issue.
Also, the stylus is very important. A lot of folks do not know how much music they are leaving on the table by using a poor or mediocre stylus. I'm not suggesting that you'all go out and get a Fritz-Gieger stylus or anything. But look at the system and see what it will support for reasonable $$ and invest a bit there.
The work that you will be doing to get the information off the vinyl is not trivial. No point in making it less valuable and less pleasing just because you are running a mediocre stylus or something.
Also, you can benefit from having a coupe of styli on hand. Say a line contact, an elliptical, and maybe even a conical that will all fit your cartridge body. There are modern conicals on carbon fiber cantilevers that will do an excellent job on some Rock and Roll pressings from back in the day. You can swap them to get around record wear patterns and such so that you get the best signal possible w/o having to re-align the cartridge and rebalanced the arm, etc.
Up to a point it is a mechanical system. Like all mechanical systems it can benefit from thoughtful tuning and handling. Make sure the LPs are as clean as you can get them. If all this stuff is working well, you can expect to get very good results and maybe better than what's out there in the commercial CD market, given their propensity to over compress and over amp the signal on modern CDs :(
