I own a pair of Rogers JR-149 loudspeakers. Recently I purchased a Rogers LSB1 subwoofer with the hopes I could mate it with the JR-149s. The problem is the LSB1 was designed specifically for the LS3/5A loudspeaker. I think what Rogers was attempting to do with the LSB1 was to match the sensitivity and eliminate the LS3/5A LF bump. I believe the LF bump is what makes the LS3/5A incompatible with typical subwoofers. Also the LS3/5A sensitivity is 82.5 dB while the JR-149 is 90 dB. What I'm attempting to do is modify the LSB1 crossover so it is better suited for the JR-149. The reason for my post is to share this information and hopefully get some feedback from more knowledgeable and talented people on how to better mate the two speakers. I'm attaching the circuit diagrams for the LSB1 original and modified crossover.
Note: I intend to label the LSB1 as being modified and will leave the wiring diagrams and removed components inside the enclosure for future reference.
